#1 |
Hội viên
![]() Tham gia ngày: Aug 2008
Bài gởi: 57
(View Stats)
Đã cảm ơn: 151
Được cảm ơn 25 lần trong 14 Bài viết
Chưa có đánh giá
0 score
CATIA File Conversion? CATIA V5 and V6 can directly use the CATIA V4 models, but changes in the CATIA data structure requires data conversion from CATIA V4 to V5/V6. This is due to both a change in geometric kernel between CATIA V4 and CATIA V5, and changes in the CAD data structure between CATIA V5 and CATIA V6 - wikipedia.org Giả sử có ống phi 10 dày 1 mm. Bây giờ em muốn đập bẹt đầu ống một đoạn 25mm có tiết diện hình chữ nhật như hình vẽ thì làm bằng cách nào. Mong mọi người giúp đỡ. Em mới học solidwork. Em cám ơn rất nhiều
SolidWorks - History & Market
SolidWorks was introduced in 1995 as a competitor to CAD programs such as Pro/ENGINEER, I-DEAS, Unigraphics, and CATIA. SolidWorks Corporation was founded in 1993 by Jon Hirschtick, who recruited a team of engineers to build a company that developed 3D CAD software, with its headquarters at Concord, Massachusetts, and released its first product, SolidWorks 95, in 1995. In 1997 Dassault Systèmes, best known for its CATIA CAD software, acquired the company and currently owns 100% of its shares. SolidWorks was headed by John McEleney from 2001 to July 2007, and is now headed by Jeff Ray.
Solidworks Corp. has sold over a million licenses of Solidworks worldwide. The Sheffield Telegraph comments that Solidworks is the world's most popular CAD software. Its user base ranges from individuals to large companies, and covers a very wide cross-section of manufacturing market segments. Commercial sales are made through an indirect channel, which includes dealers and partners throughout the world. Directly competitive products to SolidWorks include Pro/ENGINEER, Solid Edge, and Autodesk Inventor.
www.meslab.org
#2 |
Quản lý tập sự
![]() Tham gia ngày: May 2009
Đến từ: HCM
Bài gởi: 262
(View Stats)
Đã cảm ơn: 505
Được cảm ơn 167 lần trong 75 Bài viết
Chưa có đánh giá
0 score
Chưa rõ câu hỏi của bạn, có thắc mắc gì bạn có thể PM trực tiếp yahoo với mình nhé. Dưới sign
Nếu như hình minh họa của bạn, từ tiết diện tròn làm sao có thể dập về góc 90 độ vậy đc, mà đường kính của ống cũng không đáp ứng đc yêu cầu theo hình chữ nhật như hình bạn yêu cầu
Overview of Pro Engineer:
Pro/ENGINEER, PTC's parametric, integrated 3D CAD/CAM/CAE solution, is used by discrete manufacturers for mechanical engineering, design and manufacturing.
Created by Dr. Samuel P. Geisberg in the mid-1980s, Pro/ENGINEER was the industry's first successful rule-based constraint (sometimes called "parametric" or "variational") 3D CAD modeling system[3]. The parametric modeling approach uses parameters, dimensions, features, and relationships to capture intended product behavior and create a recipe which enables design automation and the optimization of design and product development processes. This powerful and rich design approach is used by companies whose product strategy is family-based or platform-driven, where a prescriptive design strategy is critical to the success of the design process by embedding engineering constraints and relationships to quickly optimize the design, or where the resulting geometry may be complex or based upon equations. Pro/ENGINEER provides a complete set of design, analysis and manufacturing capabilities on one, integral, scalable platform. These capabilities, include Solid Modeling, Surfacing, Rendering, Data Interoperability, Routed Systems Design, Simulation, Tolerance Analysis, and NC and Tooling Design.
www.meslab.org
__________________
========================================================= Đừng tự hào khi ta nghèo mà ta giỏi Hãy tự hỏi vì sao giỏi vẫn còn nghèo ========================================================= Cần hộ trợ xin liên hệ:Yahoo: nguyenthai_ind Handfone: +84954.373.373 - 84975.084.084 - 84919 190 159
| Những người đã CẢM ƠN nguyenthai_ind vì bài viết hữu ích: | namphuongspkt (13-06-2009) |
#3 | |
Chuyên gia cao cấp
![]() Tham gia ngày: Aug 2007
Đến từ: Hà Nội, Việt Nam
Bài gởi: 1,137
(View Stats)
Đã cảm ơn: 404
Được cảm ơn 897 lần trong 377 Bài viết
Chưa có đánh giá
0 score
Trích:
1. Dựng 1 sketch (sketch1) cho ống và phần tóp đầu (VD: ống D50, phần tóp đầu 130 x 15). Trong thực tế, nguyên công này thuộc về gia công áp lực và để đảm bảo khả năng công nghệ, tiết diện mặt cắt ống và phần tóp đầu phải như nhau (a * b = pi * r^2). 2. Tạo ống có chiều dày t (VD: t=1.0) 3. Dựng 1 mặt phẳng cách đầu ống 1 khoảng L (VD: L50), do khi tóp đầu luôn có một đoạn chuyển tiếp giữa 2 tiết diện khác nhau. Trên mặt phẳng đó, dựng sketch có biên dạng đầu tóp (convert từ sketch 1). 4. Làm tròn các góc với R > t (theo thực tế, các góc uốn luôn có R). 5. Dùng lệnh lofted để tạo phần tóp đầu: ![]() 6. Do tóp đầu ống, nên khi loft, đánh dấu chọn phần chiều dày (thin feature) với giá trị t1=t (chú ý hướng của chiều dày giống với ống ban đầu). 7. Điều chỉnh khoảng cách từ đầu ống đến mặt tóp cho phù hợp nếu cần: 8. Hoàn thành: thay đổi nội dung bởi: worm, 13-06-2009 lúc 03:13 PM. |
| The Following 3 Users Say Thank You to worm For This Useful Post: |
#4 |
Hội viên
Bài gởi: 57
(View Stats)
Đã cảm ơn: 151
Chưa có đánh giá
0 score
Glossary of Engineering Terms (wiki quotes): Pro Engineer by PTC? Pro/ENGINEER is a parametric, integrated 3D CAD/CAM/CAE solution created by Parametric Technology Corporation (PTC). It was the first to market with parametric, feature-based, associative solid modeling software. The application runs on Microsoft Windows and Unix platforms, and provides solid modeling, assembly modelling and drafting, finite element analysis, and NC and tooling functionality for mechanical engineers. |
#5 | |
Chuyên gia cao cấp
Bài gởi: 1,137
(View Stats)
Đã cảm ơn: 404
Chưa có đánh giá
0 score
Trích:
- trong thực tế, dù có đập bẹp thế nào thì vẫn luôn có khe hở bên trong, không thể kín khít như bạn dựng.Ngoài cách dựng như vừa nêu, còn một cách dựng khác mất công hơn một chút nhưng tùy biến được nhiều hơn, tớ sẽ up trong bài viết tiếp theo (giờ phải đi về vì hết giờ làm việc rồi). |
| Những người đã CẢM ƠN worm vì bài viết hữu ích: | namphuongspkt (13-06-2009) |
#6 |
Hội viên
Bài gởi: 57
(View Stats)
Đã cảm ơn: 151
Chưa có đánh giá
0 score
Vậy chừng nào rãnh worm giúp tớ nhé, thử phương án khác xem cái nào gần với thực tế nhất. À mà lúc tớ lofted boss/base không để thin feature thì nó mới cho còn check vào thì không dựng được?. Chọn kiểm merge result thì nó chỉ có phần vừa lofted còn phần ống mất tiêu?
Glossary of Engineering Terms (wiki quotes): Industrial Design?
Industrial design is a combination of applied art and applied science, whereby the aesthetics, ergonomics and usability of mass-produced products may be improved for marketability and production. The role of an industrial designer is to create and execute design solutions towards problems of form, usability, user ergonomics, engineering, marketing, brand development and sales.
#7 | |
Quản lý tập sự
Đến từ: HCM
Bài gởi: 262
(View Stats)
Đã cảm ơn: 505
Chưa có đánh giá
0 score
Trích:
Thắc mắc gì nữa cứ post lên để anh em cùng giải quyết nhé ![]()
__________________
| The Following 2 Users Say Thank You to nguyenthai_ind For This Useful Post: | namphuongspkt (13-06-2009), worm (13-06-2009) |
#8 |
Hội viên
Bài gởi: 57
(View Stats)
Đã cảm ơn: 151
Chưa có đánh giá
0 score
Ý mình muốn hỏi về cách vẽ thế nào để thể hiện được đúng thực tế đã gia công, tức là giả sử ta có ống tròn phi 10 dày 1 mm, gia công bằng áp lực (như bạn worm đã nói) đầu ống 1 đoạn khoảng 25mm để ra được phần đầu ống như mình đã vẽ giả sử khe hở sau khi tóp là 0 thì solidwork có những công cụ hỗ trợ cho ý đồ thiết kế của tớ không. Một phần là để kiểm nghiệm xem ý đồ thiết kế so với thực tế gia công khác nhau nhiều không? Cám ơn các bạn vì mình mới làm quen với solidwork và còn nhiều điều chưa khai thác hết khả năng của phần mềm.
Glossary of Engineering Terms (wiki quotes): What is Metallurgy?
Metallurgy is a domain of materials science that studies the physical and chemical behavior of metallic elements, their intermetallic compounds, and their mixtures, which are called alloys. It is also the technology of metals: the way in which science is applied to their practical use. Metallurgy is commonly used in the craft of metalworking.
#9 |
Chuyên gia cao cấp
Bài gởi: 1,137
(View Stats)
Đã cảm ơn: 404
Chưa có đánh giá
0 score
Cách thứ hai:
Glossary of Engineering Terms (wiki quotes): What is Steel?
Steel is an alloy consisting mostly of iron, with a carbon content between 0.2% and 2.1% by weight, depending on the grade. Carbon is the most common alloying material for iron, but various other alloying elements are used, such as manganese, chromium, vanadium, and tungsten. Carbon and other elements act as a hardening agent, preventing dislocations in the iron atom crystal lattice from sliding past one another. Varying the amount of alloying elements and form of their presence in the steel (solute elements, precipitated phase) controls qualities such as the hardness, ductility, and tensile strength of the resulting steel. Steel with increased carbon content can be made harder and stronger than iron, but is also less ductile.
1. Các bước đầu tiên cho dựng ống và profile phần tóp đầu như cũ. Chú ý: để đảm bảo tính thực tế, biên dạng của hình chữ nhật sau tóp đầu nên lấy như sau: a = (pi * r ^2) / b, với a - chiều dài, b - chiều rộng, r - bán kính ống. Đối với các kiểu biên dạng khác thì phải đảm bảo nguyên tắc "diện tích không đổi".Theo ví dụ, đó là kính thước có ký hiệu quotation (xích ma) phía trước. 2. Trên mặt đầu ống, dựng 2 sketch theo đường kính ngoài và đường kính trong (sketch 3, 5 --> chiều dày t). Trên mặt phẳng cách đầu ống khoảng L cũng dựng 2 sketch tương ứng (sketch 4,6) cho mặt ngoài và mặt trong (theo biên dạng sau khi tóp đầu --> chiều dày t1 là khoảng cách giữa mặt trong và mặt ngoài là chiều dày ống sau khi tóp). Nếu ống vừa tóp vừa bị kéo thì t1 <t; nếu vừa tóp vừa chồn thì t1 > t; nếu chỉ có tóp đầu thì t1 = t. Chú ý: khoảng cách giữa hai đường biên dạng trong của phần tóp phải lớn hơn 0 (nếu đập bẹp thì nên có giá trị < 0.05). 3. Dùng lệnh lofted để dựng phần chuyển đổi (dạng khối đặc), chú ý chỉ dùng sketch bao ngoài (theo vd là sketch 3 & 5). Nếu không dùng sketch 3 mà chọn ngay đường kính ngoài của ống thì sau khi loft sẽ chỉ còn phần chuyển đổi (nếu không chọn thin feature). 4. Kết quả sau khi lofted: 5. Dùng lệnh lofted cut để tạo phần lòng trong (khoét bỏ ruột). 6. Áp dụng lofted cut như sau với sketch 5 và 6 (sketch đường kính trong): 6. Kết quả hoàn chỉnh sau khi lofted cut (tương tự kết quả của cách thứ 1): 7. Tuy nhiên, bạn có thể tùy biến phần biên dạng trong của đầu tóp (sketch 6) theo ý muốn. Yêu cầu: biên dạng kín, không có đường giao nhau. VD như sau: 8. Theo cách ở mục 7, thu được kết quả cuối cùng: 9. Chú ý khi tùy biến biên dạng trong: chiều dày ống phải đảm bảo đủ dày, nếu không trong quá trình lofted cut, ống sẽ bị thủng. 10. Khi chiều dày vừa đủ, biên dạng tùy biến (đường kín, không giao nhau): 11. Trang trí thêm tí chút: ![]() @namphuong: trong solidworks, không cho phép tồn tại khoảng cách có giá trị 0. Vì vậy, bạn không thể loft từ 1 biên dạng bất kỳ về đường thẳng. thay đổi nội dung bởi: worm, 13-06-2009 lúc 11:21 PM. |
| The Following 2 Users Say Thank You to worm For This Useful Post: | namphuongspkt (14-06-2009), nguyenthai_ind (13-06-2009) |
#10 |
Hội viên
Bài gởi: 57
(View Stats)
Đã cảm ơn: 151
Chưa có đánh giá
0 score
Cám ơn các bạn mình đã làm được như worm chỉ dẫn.
![]() ![]() Thật ra chi tiết của mình là một thanh chống, thay vì phải hàn tai vào đầu ống để bắt bu-long thì mình cho đập dẹp ra lấy mặt phẳng bắt bu-long cho dễ dàng hơn. Về phần gia công thì dễ dàng không cần phải bản vẽ gì cả nhưng mình muốn qua đó để thực tập, tìm hiểu thêm về khả năng của solidwork. Một phần mềm thiết kế mà theo mình rất trực quan và khả năng tùy biến lớn. Mong được chỉ giáo nhiều hơn. thay đổi nội dung bởi: namphuongspkt, 14-06-2009 lúc 01:49 AM. |
| Những người đã CẢM ƠN namphuongspkt vì bài viết hữu ích: | worm (14-06-2009) |
| Bookmarks |
Trao đổi Logo & Liên kết - xin liên hệ: info@meslab.org . Hotline: 097 969 2810 |
| Ðang đọc: 1 (0 thành viên và 1 khách) | |
| Ðiều Chỉnh | |
| Xếp Bài | |
